Great help and many thanks to you both. I have just given the hull it's second application of epoxy for today. The previous coat having become 'tacky'.
In >24 hours. I will sand it as smooth as I can and apply the epoxy primer which is coloured white and according to the instructions will fill small flaws. When that's cured, it'll be sanded and that will show any 'valleys' as the white is sanded off the tops!
After that it'll be enamel -primer as often as necssary!- followed by enamel topcoat.
After all your kind efforts, I'll have to post a photo irrespective of the resulting finnish.
I saw a matt black Porsche the other day -you couldn't see much detail on that! So there's always the possibility of a matt black 'stealth' hull!
Many thanks again, should have a result by early next week.
George
