The lead bulb has been cast, but not in a closed mold as I was plannimg, it would not hold the moulten lead,it all ended in the baking tray that the mold was in,so it was back to my usual method of casting in two halves and joining them together with epoxy, a bit more work but I still get a lead bulb.
The gauging rings are the ones that I made to finish the pattern to size, the bulbs as cast came in at just over 2.5 kilos, so had to be pared down to allow for the weight of the fin.
I use a small Surform to remove the excess lead,it shaves it off in small pieces of swarf, and leaves a good finish, I always wear gloves and a face mask when doing this job and get a coat of primer onto the raw lead as soon as possible.
The spruce built hull has now had all the deck fittings put on and the closed winch line fitted,I have left the spare line on until the mast and sails have been rigged as I am not sure how much travel will be needed and I may be able to shorten the lines and get a longer piece of elastic to tension the lines.
Regards.
Eddie.
