18650 batts in model boats
Home Forums R/C & Accessories 18650 batts in model boats
  • #96815
    Former Member
      @formermember67585
      [This posting has been removed]
      Former Member
        @formermember67585
        18650 li ion battery usage in model boats
        #96823
          Phil.i think you will find that most boats run on Nimh batteries. Just because you see the use of Lipo cells in fast boats doesn’t mean that everyone uses them.
          A fair few people still use sealed lead acid types for tugs etc as they need the weight.
          Nimhs last physically much longer thanLipo, and if you don’t need the weight reduction are not necessarily the first choice.
          Is an MFA barracuda motor ok with 24v?.
          Sorry know nothing on the other type of battery. Not heard of it being used for models.
            From my own experience at my club I would very roughly estimate that Li-Po batteries are around 10-20% of the usage.
            Of the remaining, most small boats use either NiCads or NiMHs and large boats tend to use gel type lead acid batteries. I think a lot of modellers occasionally fall into the trap of thinking that brushless motors and Li-Po packs are the be-all-and-end-all of performance when they have overlooked the fact that they do not need the performance. In most cases, unless you are into very high speed models, reliability should be a more important consideration.
            Let's face it we still race Club 500s with a brushed motor and NiMH batteries so there is enough performance in that set up to provide entertaining racing.
            Finally you mention cost, in this case there is no contest as a NiMH will give you plenty of performance and duration for a fraction of the cost of comparable Li-Pos or Li-Ion.
            I am actually very wary of any Lithium based battery as there can still be a tendency for them to be unstable both in use and during charging, what other battery uses a "blast bag" for charging? I would be very reluctant to start playing around with some that are used and were not designed for the purpose for which you are considering.
            Edited By Richard Simpson on 11/07/2021 09:01:33
            #96829
              Hi Phil,
              My only observation is that Li-Ion are used to power laptops and I don't believe they are as volatile to the charging methods as compared to Lipos which main advantage is they are light in weight compared with NiMH and great for aeroplanes.
              I'm sure you will get a much more technical reply from somebody who knows more about electrics.
              Fast discharge Lipo's is required for fast models so the "C" rating has to be around 30 in my experience not based on any theory just practice.
              Malcolm Frary
                @malcolmfrary95515
                One of my members, as part of his business, winds up with lots of laptop battery packs that have ceased to be workers. He strips them down, checks the cells (which are invariably 18650s) and uses the good ones to build packs to power his boats. Cruisers rather than screamers, but having roughly the same power demands placed on them as they had in their native laptops, they work very well. And, of course, to him they are free.
                To drive his hooligan boats he does pay real money for proper batteries.
                #96834
                  Richard, I would be surprised if NiCad batteries are much used these days as the EU banned sales years ago except for certain specialist and replacement purposes. The original packs must be on their last legs by now due to memory effect.
                    Posted by Colin Bishop on 11/07/2021 10:00:20:
                    Thanks Colin, I didn't even know they were banned!
                    #96841
                    Former Member
                      @formermember67585
                      #96843
                      Former Member
                        @formermember67585
                        #96845
                        Malcolm Frary
                          @malcolmfrary95515
                          In the model boat world, even if NiCad are available, since NiMH with better numbers at lower prices are so readily available, why go that way? For most of us, NiMH is a direct drop in replacement for NiCad, and, in packs, without the "memory" of myth and legend.
                          #96847
                            Well it certainly looks like a car windscreen washer or heater motor!
                            Absolutely no point in buying Nicad`s nowadays, as per prev post.
                            Chris E
                              @chrise
                              18650's are one of a series of batteries with different capacities but similar construction. I believe that they are used in very large numbers in most scooters and even full size car battery packs as well as many laptops etc.
                              They are great where weight matters and are much more robust than LiPo packs.
                              Be aware that the best manufacturers – Sanyo, Panasonic etc only make them up to around 3000mah. The 9000+ chinese cells that you see are works of fiction.
                              Edited By Chris E on 11/07/2021 20:19:06
                              #96849
                              Former Member
                                @formermember67585
                                #96850
                                Malcolm Frary
                                  @malcolmfrary95515
                                  It helps to know what is inside any particular cell. If it has no label, its probably a recycle item unless it came from a known pack with a label or you can do some cautious testing.. 18650's are not limited to lithium, some are NiMH chemistry, with voltage to match. Being about twice the volume of an AA, they have about twice the capability. Potentially, anyway.
                                  #96865
                                  Former Member
                                    @formermember67585
                                    #96874
                                    Malcolm Frary
                                      @malcolmfrary95515
                                      Posted by phill downes on 12/07/2021 21:01:34:
                                      thats the first ive heard that 18650 can be Nimh.
                                      I know the batteries will be coming from a top of the line scooter and thats all I know so far.
                                      I do know the scooter had a range of about 30 miles or more..
                                      once I grab them I will take some pics to see what they are….
                                      It came as a surprise to me when I read the label properly, but there it was.
                                      A goggle this morning for "18635 NiMH" did its best to show everything but that, but near the bottom of the first page was –
                                      https://www.batteriesplus.co.uk/acatalog/18650_Size_NiMH_Battery.html
                                      Not common, but they are out there. Twice the AH figure of a typical Lithium cell, but only 1/3 the voltage, so I suppose that in the same space Lithium stores about 50% more power, but with a different delivery profile.
