Hi Bob,
The Joss sticks, Len mentions, are quite good – I’ve seen these used in a tug boat. The chap who owned it had a small round wooden disc with several small holes drilled into it. along with a length of thin brass rod glued into the edge, the other end of this was bent into a U shape. any number of joss sticks would be lighted, in the safety of the open air, then pushed into the holes and the assembly lowered into the funnel with the U shape hooking over the funnel top. Quite effective with 3 sticks in. I would also recommend lining the funnel with cooking foil as these sticks give off a fair bit of heat, not to mention ash – so some form of tray to catch this would also be wise. Oh and don’t be using good ones, you can pick these up in any of the £1.oo shops.
Cheers – Ken
p.s. What a waste of a good cigar !
