Hello Terry
The term 'Intermittent Use Only' in my experience means that the pump can not be depended upon to work continually. i.e. a washing machine pump is intermittent as it only runs when the machine needs emptying but the water pump on a car engine runs consistently whilst the engine is running.
As you surmise it is probably due to the inability of the pumps mechanics to cope with the constant work load.
I agree with your theory of reducing the voltage to increase the duty cycle as this is what I do (although I drop the voltage to reduce the flow rate rather than extend the pumps life span)
Let us know how you get on
All the best
Ashley: You are correct, I do wheeze as amongst my many ailments I also suffer from asthma, although I don't know how you figured it out.
Edited By Paul T on 07/07/2013 15:45:33
