water based varnish?
Home Forums Beginners water based varnish?
  • #93724
    Terry Chapman 2
      @terrychapman2
      Hi,As a guitar builder/repairer I use a water based varnish (lacquer) often to finish the guitars. I was curious to know if this would be ok to use on my Diva?
      If not,I assume yacht is ok inside and out?
      Thanks.
      Terry Chapman 2
        @terrychapman2
        #93728
          Water based varnish is not usually the coating of choice for a model boat which is immersed in water although it can be used.
          If you are applying it over bare wood then the successive coats should bond together OK but if applied over a paint surface it tends to form a thin film which can peel off if water gets beneath it such as if the hull should get scratched,
          I don't know if the latest versions are more durable but I have also had problems with 'bloom' in the past where water gets into the surface.
          Yacht varnish is of course intended for above water application only on full size boats. Probably OK for models which don't spend much time in the water.
          Spray varnishes and clear coatings need to be applied over a compatible surface as the solvent can often attack paint and existing coatings from other manufacturers.
          I have always found the best varnish for model boating to be Ronseal Hardglaze (or its Blackfriar equivalent) which is a solvent based polyurethane and can be applied over almost anything without reacting. It is really tough too. You can thin it with white spirit. The interior variety is perfectly OK for model boat use.
          Edited By Colin Bishop on 10/02/2021 13:11:56
          #93729
          Terry Chapman 2
            @terrychapman2
            Posted by Colin Bishop on 10/02/2021 11:07:53:
            Hi Colin,thanks for that.
            Terry
            Edited By Terry Chapman 2 on 10/02/2021 11:54:09
            Edited By Colin Bishop on 10/02/2021 13:10:49
            #94034
            David Walker 17
              @davidwalker17
              I am building a pair of Fishing boats and hope to varnish them .However i was told to seal them with fiber glass .Would this be correct
              #94039
                Hi David,
                Welcome to the forum, you will get many different answers here, but if the fishing boats you have built are wooden? I would say not the use fibre glass on the outside, but many of us would use it inside to ensure watertightness. Polyester resin is smelly stuff to use, these days a 2 part epoxy laminating resin is far more popular with lightweight glass cloth on the outside of your hulls if needed, let us know what your building and maybe a couple of photos will get better answers.
                I do find yacht varnish is most suitable for model boats.
                David Walker 17
                  @davidwalker17
                  Thanks Ray .Iam no where near ready yet as iam just doing the mock in thin ply atm
                  Edited By David Walker 17 on 03/03/2021 17:25:46
                  #94055
                  Terry Chapman 2
                    @terrychapman2
                    img_0748.jpgPosted by Colin Bishop on 10/02/2021 11:07:53:
                    This is how mine came out 8 coats flattening every two coats.
                    Hardglaze good stuff,thanks for the suggestion bud.
