You really have surprised me, with not understanding my little story, and you like cryptic words!……..But don`t get upset……..You are not the only one confused
I cut out the shape of Silver Mist`s waterline…..Using 8mm plywood
I placed it in the water………and it floated normally
I found a load of 6 lb, using six unopened tins of Camping Gaz
I placed the six tins on the wooden shape and it floated………But the wood sank 12mm below the water
I realised this was suspicious at the time, because wood can`t hover below the surface…….Just like the Diver
Later, you thought the test was successful, but said that 13mm was the theoretical correct wood thickness
Later, it dawned on me that the test was flawed……..So I placed the gas tanks in the water and they had some floatation, caused by the plastic wrapping
To prove the point, I later repeated the test, using a 5lb lump hammer…..and the plank sank to the bottom
Proving that an 8mm plank lacks sufficient buoyancy
Verdict…….The water line floor in the model needs to be 13mm thick or 8mm with some buoyancy adding
Is this any clearer?
If not……Add my story to your joke page!
