Hello Ian
You may have missed an earlier post…….The cloth is already painted
Made a start on the handrail top by taking co-ordinates from the hull and transferring to the plywood
After cutting out the outer shape, the under surface was coated with PVA to avoid delamination by the bandsaw
This worked nicely, as the 10mm wide annulus was cut out
If this model is 1/12 scale, the stanchions are only 2`- 0" high……This height was taken off the plan?
I`m sure handrails would be about 3`- 0" high, normally?
Need a think now……….How high are your handrails, Ray and Ian?
