Thanks very much for the info on this motor. From the data on the German web site that Paul T linked to, this is a Marx Hectoperm. 52 mm in diameter (I was close) and it's the same weight, 300 gm. Web site entry says it's 50 watts max so I guess it wouldn't pull much over 8 amps at 6 volts and a 15 amp speed controller should be ok.?
I'll test it anyway, motor does look in good condition. I suspect it will be low reving and high torque, which would be ideal for the fishing boat which is 33" long by 11 " beam, with a deep draft.
I can sort of remember Marx motors as a make from long ago, but something like a Hectoperm would have been far too large (and expensive, no doubt!) for my teenage projects. When I got back into the hobby several years ago, everything (radio, batteries, motors etc) had changed!
The hull was in poor condition, but had been well made, all the fittings, superstructure etc was long gone. It also had a leak. I've sanded the tatty paint down, and spent this afternoon in the garden applying glass fibre cloth. Went on better than I expected. Been an interesting exercise, and the hospice shop is a good cause.
I shall see how the motor works….
