Turnigy radio
Turnigy radio
Home Forums R/C & Accessories Turnigy radio
  • #91562
    Bruce Mumford
      @brucemumford61966
      I have a Turnigy TGYi6, Mode 2 radio system, I can set up Model 1 but cqan't find the procedure for setting up another model. How do you do it please.
      Bruce Mumford
        @brucemumford61966
        #91569
          Hi Bruce
          Start on the menu screen.
          Press OK.(Model Select)Press OK.
          Should show your first model 01.
          Press up to move to model 02.
          Press Cancel (hold down for a few seconds).
          Goes back to model select.
          Press Model name and OK.
          Name your model and press cancel.
          You can go down to Sticks mode to change from mode1 to mode 2.
          Press Cancel for a few seconds.
          Takes you back to the Menu.
          To change servo setup and throttle max end points.
          Move across to the spanner and screwdriver icon.
          Harry Smith
          #91570
            OOPS !!!
            Now bind your receiver into your transmitter and you should be setup.
            Label the receiver as Model 2 and boats name .
            Harry Smith
            PS the Flysky I6 is the same unit and receivers are the same !!!
            Banggood have a self center kit as well as coloured knobs, switch nuts and switch covers.
