….purchased some 5mm Lime planks and they are just right, well finished and bend around the curves without the need for heat or steam, very nice.
Servo arrangement has been revised from that anticipated as I am going to have a deck access hatch at the stern. The split lines will be mostly hidden by "stuff" on deck. Having revised the servo arrangement in the light of this development, the supporting beam I had in place COULD have been cut to suit the servo, but it does not make much difference, only to the neatness of it.
Some grey indrcoat has been splashed on the cabin area to see what work still needs to be donr, but it is looking good.
Todays boating. Myself, with Project H, Cap`n Richard (Arr me hearties) and Noel with two small boys (and Mrs Noel). Noel had my ex-foam flyer down and running on a 3s Lipo was going well. Balance it tricky on these craft, and It might be interesting to make a slightly larger foam flyer with a more powerful brushless motor, but this time have the wings adjustable, to see if indeed we could get it to take off in a flat sort of stance and not just rocket skywards.
The Cap`n also gifted me an ancient approx. 70mm ducted fan casing and fan, sized to fit a 500 can sized motor. Hmmm..tried it at home with a "cooking" Graupner speed 600 ECO and it showed promise. It really needs a hot 600, or 500, or better still a high Kv brushless. I have added another craft to the list to use this in….
