A lot of people here on the forum may have had boats like that Richard.
Bushy has always had model boaters in it, and the i/c boats used to use the main lake (not allowed now, both I/c and use of Heron pond). The designated boating pond, called just that, had pedalos and row boats on it which I remember, and is the reason we have such a nice concrete jetty that is only 3 inches above the water level. Water flow in the park is regulated so by and large there is not much difference in jetty height through the year.
The boating pond is ok for non-controlled boats as by and large there is all-round access barring a few reeds, easily negated by use of a pole.
My big destroyer now has”H22” on the sides and rear, replacing the ones that were on there when I took delivery (made from individual strips of sticky tape, and a reasonable job, considering). Sticky vinyl letters 45mm high. A bit of a compromise, the letters on the stern are the right size and virtually fill the gap between deck and boot topping, but the side ones also 45mm are strictly speaking too small and that because the lettering is not cheap and I am mean….
Pictures of the boats in the early war show huge letters on the sides, much larger that you would think, but as the letters and numbers come as sets, you have to buy loads of sheets to get three H’s and 6x 2’s. I did think Of re-numbering it, but in deference to the original builder I kept is same as.
A few new men have been painted and will be stuck on today and if I make an effort a couple of the shipsboats might get mounted. The Davits feet have holes in for really weeny nails or screws but these ones are glued on…and are very easy to knock off. I may have to look at this and perhaps get the Dremelly thing out and see if I can pin them in place.
Not that it matters but the acrylic hatch (unseen) on the Stingray is a bit of a dogs dinner now and I think a new one will be required after I finish testing, when it’s warmer.
Ashley. Next sailing…Sunday morning…9 sharp especially if warm and sunny. Big destroyer possibly???
…..shock horror….just “found” a picture of the Destroyer as received and my side letters are either about same size or a bit bigger! They are also higher than the originals..tricky, as the portholes were in the way. Snaps in Mintanic album, for some reason.
Edited By ashley needham on 08/04/2021 08:22:11
Edited By ashley needham on 08/04/2021 08:43:40
