Yes nice to see Woddy again,,…?
A park man said when interrogated with a razor sharp spinning prop hovering over his throat that…
the park staff don’t manage the valves sluices and so on, it is a private company (name forgotten) so I think we can assume that their staff have been furrowed and so the RoyalParks can’t get the valves twiddled.
You can see what's happening. As we sat (unsocially distanced..after all, if you were sitting socially you would be sitting close.??) the scummy muck (not those on the jetty, they were just scum) and leaves etc were being blown to the silted corner, just piling on the vegetable matter big time. It piles up, sinks then rots. Yuk.
Swordfish ok, barring the rudder catching debris, so some rudder alterations will take place today to get the top of the rudder behind the stern so the muck slides off, and a couple of underwater strakes to be added as water was climbing up the side just a bit.
Jet lander not as good as hoped for but hampered by the esc which is obviously set for Lipo,and cut out twice on a Nimh before we twigged it. Will enlarge the inlet a bit, and the was some clag in the tube so assuming that half the issue was the scummy stuff being ingested.
