Progress on the Bluebird propulsion. The inscrutable vendor has refunded my fan purchase.
This means I have two fan/fan casings, 12 bladed, free of charge, not quite of course as I have to buy a motor for one of them, and that will cost as much as the fan/motor wot I oredered.
The original had 5 blades and a 4500Kv motor, this will have 12 blades and a 3500Kv motor. What does this mean, practically speaking you ask ??? No idea! It does mean the boat will sound slightly less frenetic.
Next issue is that the mounting projections are only 3mm wide, not really enough to drill and get a screw through. I might put a notch in the side and use screws, with small washers? I don't suppose the plastic will glue very well. On the upside I have loads of room to fiddle.
