Richard, we will look forward to seeing your flat bottom soon.
Disaster on the Bluebird EDF front. Instead of sending a 64mm 5 blade fan unit with 4500Kv motor the inscrutable Chinaman has sent a pair of edf ducts and 12 blade fan units (with couplings). This is no good! The new ducts are moulded for a motor about 21/22mm in diameter…some of them seem to show an odd brushless out-runner motor with a long flanged end, and so are useless even for playing with as almost nothing will fit unless you get the right motor.
Why don’t I keep the fans and get the correct motors?? It is an issue of current draw. More fans means more load, and 4s is the battery specified for the whatever motor should be on these units, and mentions of 35/40 amps gets bandied about! My 4500 motor is for 3s.
i will have a spare 20mm motor but the shaft is 2mm and the 12 blade fan adaptor looks to be 3mm or 3.17.
Other than that the build is coming on. Too easy really…the fuselage is almost done, the sponsons need some artful sanding, the sponson support 4mm carbon fibre rods are in. Barring waiting for the motor the next and tricky bit will be making the fuselage top. This is projected to be made from 0.8mm ply, two pieces and will be removable for access but I have no idea how to either mould it to keep the curve or attach it to the main body. Ply hoops would be the way but I want as clear an inlet as possible, and at the moment the motor will be in the middle of the cockpit-tail bit, limiting where hoops can go. I could use sheet styrene for the top, and spring it in place….hmmmm.
Edited By ashley needham on 15/01/2020 08:53:34
