After an inspiring visit to the Warwickshire show a few weeks ago, I’m resuming the build of a Fireboat 39 model, using the plan from the Model Boats range. Building began ten years ago, but was abandoned after I’d built the hull, mostly from plywood.
I also dusted down a timber-hulled model that I completed before beginning the Fireboat, but on its first trip after re-commissioning, one of the timber hull’s joints split open, allowing water on board. Thankfully I noticed in time and brought her ashore before any electrical bits got a swimming lesson. On several occasions this model had sailed perfectlywithin a year or two of being built, but I’m wondering if the paint had become porous with age. After reading other posts on this forum, my intention is to line the hull inside with resin, and to rake out the cracked joints outside the hull, fill them with resin, paint over and try her in the water again.
I also intend to treat the Fireboat in the same way before it’s painted.
My question is how can the outside surface of a hull be made smooth if part of it – or even the whole hull – are covered in resin which can’t be sanded down.
What do you guys recommend?
