Thanks Mattias
They are really cost effective If slightly larger than 1/24th scale, but I do need somebody at the helm
Turning some pulleys for the cable operated rudder, brass rod centre drilled and drilled out clearance for 1/16" rivet, move the tool round to cut the V in the pulley and parted off, my decent parting off tool is so wide but cuts true. 3 different diameters, deck mounted sheaves next thinking about press/jig to form the double bend required.
