Thanks for the welcome
The Victory has ome oddly designed features too, looks similar to your "Sovreign" in construction. The hull is planked with 5×1.2mm strips, using brass nails, then a layer of veneer of darker wood is glued over the top of that. Not that I got that far with the Victory. I had finished the keel and all the ribs, and fitted some of the decks, then planked the decks, that is when I noticed that one of the ribs was misaligned
Of course it was a rib that was held in place by the deck I had fittted, so I couldn't remove it and fettle it to fit.
When I finally get back to it, I will probably build up the rib with thin strip wood, then sand it back down to the correct profile, and should be able to carry on from there.
Getting on with building "Jenny" at the moment.
Ricky
