Hi Ron.
All these questions are a bit like asking 'How long is a bit of string?'….The fact is, no-one can answer them without knowing a lot more about the boat, size, type, shape, weight and intended use or even, how fast do you want it to go.
Anybody who does give you sizes and numbers need to know all of the above as well as what motor are you intending to use….Then only experience can lead them to hazard a guess at what could work for you…and they could still be wrong!
Kit builders and boat plan designers have usually sorted out these problems by trial and error and will often hazard a guess or recommend a certain motor/propellor combination, but this may still not make you a happy bunny when your model chugs along like a geriatric or spins upside down when you open the throttle.
Lets try and answer a few of the queries you've listed:-
1. A Kort nozzle is designed to make relatively large propellors on things like tugs and other working boats, more efficient. Usually about 10%. If the real boat has a speed in excess of 12 to 15 knots at full power it may increase that a little but will not work above those sort of speeds. So is definately NOT suitable for your high speed powerboat. (a 2950 Kv motor is a bit over the top anyway!! in my opinion, unless it is a Jet drive)
2. Most modern props you buy, ie Carbon/nylon mix do not need balancing and this would be very hard to do anyway. If you were into racing competition boats then metal props can be bought which are usually fairly well balanced but you'll need to know what you are doing at about £20.00 plus a time. Or make your own!
3, More blades of the same pitch can cause the motor to overwork and therefore get hot, which is not good.
4. Beginners often seem to want more speed, more speed and so put bigger props on than the motor can handle, you not only need to change the prop, but the motor as well in many cases, We won't even start going into batteries.
That's about all I would actually say that I know about your questions. If on the other hand you say you have a 25 inch sporty hard chine hull runabout and a hottish 500 type motor, from experience I would say try a 35mm x 2 bladed nylon prop and maybe buy a 32mm and a 38mm as well. See which goes best.
As far as your brushless motor goes your 2950 kv at 11.1volts liPo will turn at about 33,000 rpm!!!, if you put a bigger prop on you will blow up your speed controller and / or your batteries. With speeds like this you have to let them turn….and that means a smaller prop, maybe 25, 28, 30 mm diameter tops, two blade Hydro (Coarse pitch)
(By the way 33,000 rpm is the speed my Industrial ELU router goes….insane!!)
Hope this all makes sense.
Cheers…………..Ron Rees
