Since my last post around a month ago, I’ve been painting the hull & decks, and whilst waiting for the coats of paint to dry, I’ve also been working on the various items which will be fitted to the foredeck. The paints used so far (all from the Humbrol enamel range) are as follows:
147 Light Grey – matt (hull, bulwarks, gun platform & support, etc).
140 Gull Grey – matt (foredeck).
153 Insignia Red – matt (lower hull).
88 Deck Green – matt (main deck & gun platform floor).
85 Black – satin (waterline stripe, etc).
113 Rust – matt (as per the name!).
82 Orange – matt (used for fresh rust).
For the records, I used a new compressor (which has a 3 ltr tank) bought from e-bay, which together with 2 double-action airbrushes, cost around £95. Brilliant!. I have used, however, a Badger 250-4 with an adaptor for all spraying done to date, as this can cover larger areas more quickly. As this is the first time I have ever used a spray gun/airbrush, I did a little practising on scrap material first!!.
I have found from experimentation that with matt paints, the mix can be 2 parts paint to 1 part thinners. I’m sure that gloss would probably be more like 1:1 as it is thicker.
All spray painting was done in a heated shed, and once dry (left overnight), the boat was brought into the house for the paint to fully cure. As I wanted to spray with as much daylight as possible, this was done at weekends only, and the weeks gap in between allowed the paint to completely dry before the next stage.
A few photo’s, followed by a description of what order I did things in:
As mentioned in my previous post, I started by painting the inner bulwarks, bulwark supports & capping rails (underside & top) by hand, with the Light Grey. This ensured I got into every nook & crannie, and I must say that using Humbrol enamels was the right choice for me, as coverage was superb, even from just one coat.
I then sprayed both decks & the bulwarks etc with the same colour, giving the bulwarks and supports their final coat, and the decks an undercoat onto which the Deck Green could be applied.
The entire hull was then given 2 coats of the Light Grey. The best way I found to do this was to lay the boat on it’s side, and spray one side at a time. The reason for this is that there are several rubbing strakes & plating on the hull, and painting the boat on it’s side ensured complete paint coverage.
The next weekend saw the lower Red go on, again 2 coats, and again half the hull painted at a time.
The black waterline strip was first marked onto the hull using the usual method of a stand with a pencil attached at right-angles. I have made the stand with a vertical piece of 1 inch-square wood, bonded to a wood base, around 4 x 4 inches in size. The pencil is held onto the vertical piece of wood with a clamp, which allows for any adjustment required. Once the 6mm Tamiya masking tape had been applied (VERY tricky due to the rubbing strakes etc), the black paint was applied by brush – 2 coats.
The main deck was then brush-painted with the Deck Green (3 coats), and the foredeck with the Gull Grey (2 coats).
Next were the pennant numbers, which are supplied in the kit, and the bow depth markings which are from BECC, and these can be seen in the next photo:
The bare areas of the main deck are where the 3 prined ply overlays will be fitted.
The hull and decks have yet to be weathered in the above photos.
Since my previous posting, the gun platform required a little more work prior to painting. This consisted of fitting the 0.8mm ply rim, and the 2 platforms for the storage boxes. The manual & plans are lacking in information regarding the storage box supports, and although I took dozens of photos of Mountfleets own Sir L. at the Warwickshire Model Boat Show in November last year, I was still none the wiser. (I’ve also looked at various reviews of the model, but none show this area in detail). So, modellers licence prevailed, and I designed my own supports which are as follows (note that the platform has had some weathering applied to it):
As mentioned earlier, whilst waiting for the weekend painting sessions, I decided to prepare the foredeck bits & bobs. Continued next page. . . . .
