Hi All
Just fabricating the mounts for the rudder servos. For the Huntsman 28 I'm using this Hitec Low-Profile servo as height under the cockpit floor is restricted.
As well as the usual different arms and the four screws there are four rubber whatsits and four metal sleeves. I'm assuming that the former are rubber mountings, though they are a tight fit in the servo mounting holes. Are these for aircraft use?
I've had a look on the Hitec site and downloaded a "manual" but there is no mention of these parts.
Usual practise seems to be just to use screws but do I use the sleeves as well or are those for the rubber mounts?
Thanks, Chris
PS There are four sleeves but one decided to throw itself in the corner behind the units! I can see the blighter though, surprisingly!
Edited By Chris Fellows on 25/05/2020 15:43:04
