Tissue and dope would be strong – but ply would be stronger still.
I drove my boats onto rocks, so if you don't expect to do that then it's not a problem! But my original point was that a fibreglass hull hitting a log might leave a scratch, while a 1/16" balsa hull will get damaged like the full-size would if it hit a giant log….
Having said that, the effective 'double-hull' egg-box construction means that flooding is minimised, and it's easy to repair….
There isn't much space in a 20" version. You could probably get two motors in a 28" one, though three might be a squeeze! I was expecting some torque roll from my single motor (given how narrow the hull is), and was surprised to find there was little or none, so I would still go for a single motor at 28" – makes construction easier…
The Terrier is the obvious nostalgia boat for 1960s boys! I have an R/C one here, but it's only suitable for light-weather pond use. I'd make a smart one as an inside display piece. Here is a solid made-up one to give you some ideas…**LINK**
