I have a Graupner Regatta II sail winch installed in my IOM. It has been on the shelf for a couple of years while I did a bit of a refit on the boat and rig.
Before installing it I put it on a servo tester and all fine.
When in the boat I put it back on the tester to get the sheeting set up and found that the servo movement lagged behind the tester input. I thought maybe that was just due to the tester so I rigged up the receiver and transmitter to get the end points of travel set up and the same thing. The winch movement lagged behind the stick movement.
It then went a bit twitchy, moved a few minutes after the last stick input, twitched again and is now totally dead. I have checked it on two receivers, two batteries, and on the servo tester. Nothing at all while the rudder servo continues to operate fine.
These servos are expensive so I don't want to give up on it too easily.
Any suggestions welcomed.
Thanks
Tim R
