Rigging Query
Rigging Query
Home Forums Beginners Rigging Query
  • #78295
    Royce Barrie Johnson
      @roycebarriejohnson51364
      I am in the process of rigging my one metre yacht but am wanting to be able to de-rig it for transport . On deck there are two 2 hole securing (cleats) id call them so I need something that will clip into these and take up the forsail line and the rear stern line.. Ive looked at still hooks but seem rather crude ny suggestions would be totally welcome. Barrie (newbie to sail)
        #78296
        Empire Parkstone
          @empireparkstone
          Have you looked at fishing tackle small swivels and hooks
          https://www.amazon.co.uk/Swivels-Snaps/b?ie=UTF8&node=454756031
          #78299
          Kev.W
            @kev-w
            Take a look at 'PJ Sails' **LINK**
            On the left is a list of catagories, select 'Rig Fittings' & the top item will be PW 8c this is what most 1metre sailors are using on pleasure boats.
            On the end you can't see in the pic, the wire forms a hook.
            Edited By Kip Woods on 31/07/2018 21:51:17
            #78301
              …..and lurking at the bottom of the "deck fittings" page is PW8j, a detachable turnbuckle, but using that will probably depend on the particular eyebolt being used.
              Is the mast deck stepped or plugged into a fitting that goes deep into the hull? A deck stepped mast has different requirements to a keel stepped one because the forces going through it are much greater. I have a tendency to use stainless wire staples for that particular job.  Some like chain plates, either brass angle with a row of holes for the rigging hook and screwed to the deck, or a flat plate screwed to the hull side with much the same effect.
              Edited By Malcolm Frary on 01/08/2018 10:38:12
              #78302
                Thank you fellow sailors you've given me food for thought
                #78306
                  Glad you have found the responses helpful Royce.
                  Much cheaper than a new car!
