Bitter experience, mine was a soldered joint on a motor tab that looked ok but only a couple of strands were actually connected and acted like a bimetallic strip i.e. disconnected the power when the wire became warm.
Jon
A couple more thoughts have occurred to me.
Is the battery fully discharged after the test, if not how much charge is left?
Also you don't mention what size of battery you are using and how big the motor is.
Is anything getting hot?…..to drain a battery so fast it to be using the power for something and heat is the obvious candidate.
Edited By Paul T on 24/11/2018 17:06:14
