All of this for £150 + P&P
Brand new in box Revell Masterclass Vario airbrush and Revell Compressor. The RRP for the compressor is £156 and £85 for the airbrush, a total of £241(Models for sale.com). This equipment is professional quality and can be used for modelling, artwork or even nail painting. It is very versatile. All you need to get started is the paint. This is quality equipment so grab yourself a bargain!
Compressor Specifications
Type: Oil-free piston compressor (220 – 240 V / 50 Hz / 135 W)
Maximum pressure: 5.5 bar
Output in litres of air: 23 l/min
Noise level: 55 db
Extras: Manometer, pressure regulator, water separator, automatic switch-off system, carrying handle. Connectors: Fitted as standard with the connector (1/4 inch) A compressor adapter and hose are included
The Revell Vario Master Class Airbrush is the real all rounder amongst the Revell spray guns.
With it you can paint not only large surfaces but also tiny details as well as create great ageing and camouflage effects.
Whats in the box?
Nozzle in the set: medium. 3 jets are available, small/medium & large
Two empty paint jars
Jar adaptor
spanner
Cheers, Charlie
