Thanks to everyone that has replied, really appreciate the interest and advice this has generated, a lot of useful information here to consider already!
A little bit more info on the project:
My team and I are Foundation degree students studying a range of engineering-based topics: Naval Architecture, Mechatronics, Mechanical Engineering and Marine Engineering. We are all a bunch of novices at model boat building but all work in the marine engineering industry.
The previous photos of the bat-wing hull in my original post are photos of the plug that was used to create the male mould. This will then be used in a vacuum resin infusion to create the composite hull. (Therefore those wooden frames will not exist in the composite product.)
Length: 900mm Width: 370mm Depth:140mm
Displacement (Hullform only – unladen): 3.359kg
The vessel will be fully autonomous: to include propulslion, steering and load delivery. The race lake we are using has full wifi coverage to support this. The mechatronics member of our team has drawn the short straw on this one because I admittedly have very little knowledge on that specific subject. I will keep this thread updated as to how we are to go about programming this once I have spoken to him on Friday!
We have short listed the load delivery system to:
- A centre-line actuator that will push two hoppers to tip overboard (1 to port and 1 to starboard.)
- A lightweight frame construction that will sit on top of the deck, with a pully system to pull two hoppers overboard.
These ideas were shortlisted as the actuator/pulleys will be positioned on the centre line and will allow for even distribution of the payload weight (1kg per side). We are leaning toward the frame design as it will be easier to remove for the endurance and sprint challenges!
We are to choose between 7 different speed-controllers, 4 motors and 4 batteries . We must also use a 3/16” Drive shaft.Aside from these limitations, we must everything else through research.
Regarding rudder selection it seems that I should write off the idea of an offset right rudder. I was reading other forums suggesting that centre-line rudders can sometimes make the vessel unstable in a straight line due to the rudder being in turbulent rather than “clean water”. Not sure how much of this is true, but maybe that theory is just reserved for high performance models.
I have began to look at the above mentioned examples of model boats and I can definitely see some similarities. Thanks for all the info again, ill keep this thread posted on how we are getting on. Race Day is in May. We order all parts for a fortnights time where building and testing will commence.
Fingers cross it works haha!
