Pulling my hair out !!!!
Home Forums Soapbox Pulling my hair out !!!!
  • #8079
    Andy Hustler
      @andyhustler32076
      Andy Hustler
        @andyhustler32076
        Any one out there built the revel snowberry without a hitch or is it just me !!!
        I have found that the bulkheads on the rear deck fitting are bowed , 30mm at either end and going up to 33mm as it goes along towrds the centre so with much swearing filler and superglue i have got the things to fit , i only hope the rest of tjhe kit is not going to be as bad as this , c'mon revel pull your socks up !!
        #58466
        Charles Oates
          @charlesoates31738
          Hi Andy, it’s over 10 years ago since I built mine, so the kit must have changed. Mine went together without any problems, but there weren’t any bulkheads in the kit, though I did add some to the hull made from ply to keep the hull rigid and also to keep the forward balast in place.
          #58468
          Andy Hustler
            @andyhustler32076
            Thanks charles i just dont understand i've never had problems before revel normaly produce a good kit and i find it intresting that where its made is rubbed off from inside the hull
            #58469
            Charles Oates
              @charlesoates31738
              That’s weird, makes you wonder.
              A search of the internet will bring up a lot of other peoples builds and conversions, then you could compare yours to the others.
            Home Forums Soapbox Topics
