Prop-2
Prop-2
Home Forums Beginners Prop-2
  • #12191
    Len Ochiltree
      @lenochiltree67043
      Hi Bob, Can you clarify is this a Right or Left hand prop?, and if I use just one prop does it matter which I use?.
       Len.
        Hello Len
        This is a LH prop
        LH props automatically tighten on the RH shaft thread when going forward…….This way, there is less chance of shedding the prop in normal use
        Besides……..Brunels prop was LH anyway……….The retaining screwed collar would have a RH thread and the drive from the shaft would be via a key
        I hope I`ve got that right!
        #1495
        Len Ochiltree
          @lenochiltree67043
