Hi, haven't posted on here for a while but have been slowly moving a couple of projects on (plus operating current boats) but do enjoy reading the various forum topics.
Ok, advice now needed. I've got my Revell Corvette to a point where I can try it out. various flotation trials in test tank (aka the bath), got radio, motor speed control and rudder working fine. I'd previously run the motor connected directly to the battery for some time to try out various propellers , settled on one where the motor drew under 1 amp on 6 volts.
Having fitted and tried the electronics, I took ship down to the pond on a very calm day this week. Looked like I'd got the ballasting ok as it sat very well in the water. she was very controllable, ahead and astern, enough power to go above scale speed, but throttled back went at a scalish looking speed. Also steered very well. All was well for 20 mins or so.
Then disaster, everything cut out and the ship was stationary. Neither the rudder or prop would turn. Turning transmitter on and off did nothing. Eventually the model drifted to the other side of the lake.
1. there was no power to the radio. (green or red no signal light not on)
2. I turned off the switch to the esc then turned it on again. This time there was power, could run motor forwards and backwards, and operate rudder.
I've tried this again in the bath (so under load). Moving rudder to full position seems to cause the motor to hesitate as if there is a small blip where the current is cut off. If the motor is running slowly this makes it stop then it won't restart and power is cut off to motor and servo. Turning esc switch on and off then resets it.
The battery is a 6v 3.4 a/hr lead acid one. The voltage after 20 mins was just under 6 volts. The motor is an MFA 385. The esc is an mtronics viper marine 15 and the radio is Tamco with a 6 channel receiver. Servo is just standard. All very straightforward kit, all components new for this boat (existising transmitter with new receiver, bind was fine). That sort of set up has been fine in other boats and very reliable.
Has anyone had any problems similar to this? Not sure which part to change first – higher voltage battery? Could it be servo suddenly drawing a high current, or faulty esc perhaps ?
Advice gratefully received!
