Powerful motors
Powerful motors
Home Forums Beginners Powerful motors
  • #12056
      Message for Manxman
      Hello Ken………………..You mentioned a make of motor………"POWER 1000"
      More information please…….speed…….size……….price……..and where do I get them from?
      Need to plan ahead………..thanks!
      Bob the Builder
      Manxman
        @manxman
        Hi Bob,
        The Pacific Light I’m building is only 48" in length but will be extremely heavy.  My choice of motors (2) was I needed power and not speed, I also don’t like using gearboxes as they add extra noise.
           Details:
           Supplier = Westbourne-models.com
           Robbe Power 1ooo motor
           Current amps @ max efficiency = 2.5 amps
           Maximum power = 10.oo amps
           Revs = 650
           Efficiency = 70%
           Weight – 1ooog (1kilo)
           Length = 96mm
           Voltage = 6v-12v
        Suppressors – here you may have a problem. Normally we would fit 3 capacitors to suppress any electrical noise, however I have only been able to fit one, across the power terminals inside the motor as there are no external terminals. The motor is held together by two lengths of screw thread which pass through the full length of the motor, but these do make mounting them easy through 2 half height bulkheads.
        Now if that hasn’t put you off – the next bit of info will…
        You will need to be sitting down for this …
        Cost = £37.99 + postage !
        If you have used nitro engines before you may already have a motor. The electric starters for these engines use a similar motor.
        I also intend to fit these motors into my Imara tug
        Cheers – Ken
        #12065
          Hi Bob
          This might sound daft especially with you and Ken talking about such big powerful motors but have you considered using geared meccano motors to drive the paddle wheels.
          When geared to the slower speeds they are very powerful and should rotate the paddles at the right scale speed, they will also take up less space in the hull especially as they will be sitting transverse.
          By the way the build is looking very good.
            Thanks Paul
            Don`t really fancy Meccano motors for some reason………I`m looking for something brutish and powerful…….especially for the prop
            The paddles will have a chain reduction drive anyway.
            I don`t want to crawl round the pond at a puny scale speed…….not that I`ll go charging about like a Loony!……….I like the idea of getting somewhere fast when I need to!
            The Robbe motors sound ok but not impressed with the capacity nonsense!
            Regards Bob
            #12068
            Manxman
              @manxman
              Hi Bob,
              Just had a thought about the suppressor.
              There may be a way of fitting without opening the motor.  Not sure of the name I think they are "Scotch Locks", we use to use them on cars to connect accessories without cutting the wire, don’t know if you remember them. Still available at Halfords and the like.
              Could also just "nick" the insulation, solder the capacitor lead on and then slide a little heat shrink on.
              I agree the capacitors are a pain but I’ve already done them,  however when I come to use them on the Imara, I think I’ll go with the nick & heat shrink idea. That way I’ll be able to get all 3 on.
              Ken
              #12088
              Len Ochiltree
                @lenochiltree67043
                Hi Bob&Others,
                Have you thought of using Wheelchair motors?they sometimes get changed for not much reason,also batteries, so chat up your local Mobility Repair shop.
                I also heard of a chap using car electric window motors, they have a right angle drive.
                  Len.
                #12089
                Manxman
                  @manxman
                  Hi Len,
                  I wrote a nice little reply there to your suggestion, but deleted it as I do not wish to be thrown of the forum or bring it into disrepute for bad language – may work for other people, but for me, from past experience with these mobility guys will give the idea a miss.
                  The window idea is a good one though.
                  Cheers – Ken
                  #12116
                  Sandy Thomson
                    @sandythomson
                    Another suggestion Bob, is the motors which raise the seats in the Ford Granada, up and down.
                    Try any scrap yard       AT
                    #12117
                      Thanks for that Alex…….I really want something more user friendly than that
                      Another thing is that the motor is only 1.5" above the inside of the hull!
                      I keep looking at the MFA 800 motors with mechanical controller?……..Too small?
                      #12118
                      Manxman
                        @manxman
                        Hi Bob,
                        Quote : "the motor is only 1.5" above the inside of the hull" – does this refer to the center of the prop shaft ? – meaning you could fit a motor up to 3" diameter.
                        Your looking at the MFA 800, but reckon they are too small, can you fit two of them ? – with a belt drive as in the severn class lifeboat featured in MB.
                        When I fitted the 1ooo’s, I did not have much height due to the angle of the shafts. The motor mounts were two lengths of ply glued each side of the motor.  The space was filled with silicone, motor wrapped in clingfilm and replaced.  Took 3 days to cure, but ended up with a bed that was a perfect match, absorb any vibration and stopped any noise transferring to the hull.
                        Cheers – Ken
                        Hey – its just another idea to ponder over, no need for a metal motor mount.
                        #12120
                          Yes Ken…….3" dia is the max……..but they can`t be side by side……too narrow in the vee area of the hull……..tandem would be the answer…….but no tail end shaft!
                          But don`t forget……..Brunel added paddles as well?……..Perhaps one motor would be suffice?
                          Thanks for your input
                          Bob the Builder
                          #12287
                            Ken,
                            Sainsbury`s are selling 14v battery drills for………..£8.00!……cheap as chips!
                            They run at 550 rpm………………..What is your tugboat top speed?
                            Just tried my prop in a bowl of water, with the drill at top speed…….and it looks OK to me?
                            Manxman
                              @manxman
                              Hi Bob,
                              No idea as yet, the only water shes seen has been going into my whisky !    – Still fiddling around with the railings, Once these are finished I can get the wheelhouse in place and then think of the running gear – but as usual the house is calling, just started ripping the kitchen out ready for replacement.
                              Do you remember the days when a supermarket used to sell food !
                              Ken
                              #1486
                                For Great Eastern ship
