Pot Belly Stove
Pot Belly Stove
Home Forums Soapbox Pot Belly Stove
Viewing 21 posts - 1 through 21 (of 21 total)
  • #53752
      Having got fed up of building ship models, I have just completed a Pot Belly Stove (Circa 1898). Two feet to one inch scale. Mainly wood with brass feet, brass door and brass chimney. It has a flickering red LED inside, connected via the front feet.
      Looks very good!
        Banjoman
          @banjoman
          Hello Bob,
          That stove does indeed look very good! I really like the surface, and the way you've made it look like cast iron — it has just the right amount of unevenness. And I love the fairly light but just-so touch of weathering!
          Now you just need to build a suitable boat to go around it …
          /Mattias
          Edited By Banjoman on 21/11/2014 14:40:53
          #53758
            Thanks,
            The body was turned from an old wooden broom handle. The rim round the middle is a disk of 1/32nd marine plywood glued between top and bottom halves. The ash can is splayed beading, whilst the door and feet are brass. The chimney is also brass. Sprayed first with red oxide primer, then satin black. The LED is a cheap flickering type requiring 3 Volts and only takes about 12mA. The LED is covered with a piece of kitchen roll soaked in red printer ink.
            mike farrell
              @mikefarrell21522
              Hi Bob I took my notebook to my friend to show him what you have made .He is astounded as he has just built one from a old gas bottle ,I left him hanging for a while then I told him yours is in miniature
              I had to hotfoot it out of his way ,he calmed down and said you have a hidden talent Now he is a believer of model boats not toy boatscheekyMichael
              #53774
                Thanks for replies. The stove is very large scale for me, and didn't take long to make. It made a change from ships and looks really "hot" when you see the flickering red coals!
                  What are you going to do with it Bob?
                    I thought I might make an Alaskan log cabin, 1898 era (Goldrush). Contents, pot belly stove, bearskin rug, table, chairs, bunks, axe, Winchester rifle, LED oil lamp etc. with back end open. Front half covered in snow and ice. It really depends on whether I can make the contents to my satisfaction. Stove came out OK. Next item, 2 inch long Winchester rifle.
                      I have now made the Winchester rifle to the same scale. It all looks very rough as it is enlarged here, but in real life, it looks OK
                      Edited By Bob Wilson on 23/11/2014 14:40:18
                      Edited By Bob Wilson on 23/11/2014 14:47:24
                      #53797
                      David Wooley
                        @davidwooley82563
                        Hi Bob With your skill moving over to a different perspective on model making should prove to be quite rewarding .
                        Dave Wooley
                        #53799
                          Thanks Dave,
                          I don't suppose the move will be permanent, but a change is as good as a rest!smiley
                          Whilst waiting for the paint to dry on the rifle, I made a woodsman's axed this afternoon. The rest should be easy – tables, chairs, bunks and my wife is figuring out how to make the bearskin rug. Maybe a kettle for the stove, a couple of bottles for the table. Would like a cartwheel leaning on the outside as well, that should be a bit of a challenge. The snow and ice is no problem as I have done maritime Arctic dioramas.
                          I have always been interested in Alaska and the gold rush days, as in The Trail of '98!
                          Len Morris 2
                            @lenmorris2
                            One of the buzz phrases in the technical world is 'Nano Engineering'. I think the modelling world has just caught up! Brilliant work but annoying as I'm going to have to upgrade mi specs to see it!
                            Len
                            #54136
                              I have now progressed with the cabin. It has been more tedious than I thought. The logs are dowels and the rough bark is added to each by gluing silver crepe paper round them (silver to the outside). Each log has to be notched at the ends to engage with the lower and upper ones. After it is complete, it will be painted with acrylic Burnt Umber (Dark brown), then wiped slightly so bits of the silver show through. Tests have shown that this makes a very realistic looking rough log. The floor will be planked, and the inside of the cabin fitted with more rough furniture. I have made the tiny oil lamp for a table and it is lit with a small yellow light emitting diode inside it. The back of the cabin is absent. Viewed from the front, there will be a lot of drifted snow. Looking in the back, it should show a cosy interior lit with the yellow oil lamp and flickering pot belly stove. Note the winchest rifle and the axe propped against the door frame. This afternoon, I have completed most of the front and one side. The bare dowels in the photograph have not yet had their "bark" glued on. It has been a welcome change from ships.
                              Edited By Bob Wilson on 06/12/2014 17:36:16
                              #54194
                                It was very tedious notching all the logs and putting the "bark" on, but at last, the walls are complete. Next task: floor, door and roof. Wonderful change from ship models!smiley
                                #54195
                                Banjoman
                                  @banjoman
                                  I can really understand what you mean by"tedious", but the bark effect is truly great! It absolutely looks the thing!
                                  /Mattias
                                  Edited By Banjoman on 08/12/2014 15:32:16
                                  #54199
                                    Bob, can it be that you are constructing a model SHED?
                                      Not exactly a "shed," but a "log cabin" complete with all fittings!smiley
                                      Have been making the roof beams this afternoon. Next, will be the floor and door.
                                      Really enjoying it.
                                        The cabin is well-advanced now, and I have had my first trial of the lighting.
                                        #54390
                                          The cabin is well-advanced now, but appears to be as much of a "damp squib" as models of merchant ships! Nevertheless, I am enjoying the build very much. Here is the first trial with the lighting switched on.
                                          Don't know what happened here,  the above post did not appear, but when I put it on again heresurprise, it appeared as if by magic!
                                          Edited By Bob Wilson on 16/12/2014 19:14:00
                                          #54448
                                            More progress has been made on the inside with the bunks in position and the window shutter fitted.
                                            #54492
                                              The outside is now complete.
                                            Home Forums Soapbox Topics
