Hi Robert
Hobbyking have a few 28mm water-cooled motor mounts (WTCMT01 and BP22-MMWC).
Tubing I use Silicon fuel pipe 2.5mm (OR005-00601) a metre lengths.
As for ESC's the Hobbyking car ones(HK-30A,HK-45A,HK-60ASL and HK-100).
All have reverse, I have not used the 30A, to lower Amps.
The 45A handles 2 and 3S batteries, so good for all 28mm motors.
I weight the 45A at 69 grams, 60A at 91grams and 100A at 106 grams.
Using the same program card for all, very easy to setup and very good low speed control.
These are the only ESC I use!!!
I tested a XK2845B-2000kv(280watts) in my boat, it would not pull skin of a custard.
The high kv motors maybe OK with a surface hydro prop setup which a number of boats run.
