Newbie
Newbie
Home Forums Beginners Newbie
  • #94049
    David Walker 17
      @davidwalker17
      I plan to build from scratch two Fishing boats in woodmmmtgse30ohgfcmmjhwmcrq.jpg
      The scale is 1" =1foot so the model will be 39" long.
      What i want to know is what size and type of motor i will need for this size of model
      Edited By David Walker 17 on 04/03/2021 14:30:22
      David Walker 17
        @davidwalker17
        Building two 1950s Fishing Boats
        #94050
        Dave Cooper 6
          @davecooper6
          Hello David
          Welcome to the forum.
          I'm currently at the design /scratch build stage too although mine is for a working boat under sail.
          I think the others may appreciate some extra details such as beam, estimated finished weight and draught etc if possible before venturing advice on motors.
          If it were me, I would probably go for a brushed motor with a NiMh or gel-cell type battery. However, the experts may disagree – I would go with their advice primarily.
          Happy modelling,
          Dave C
          #94057
            Hi David,
            They look like interesting craft, do you have drawings yet ? motor wise I would look at an 850 size brushed driving a 2 1/2" prop and a sealed lead acid SLA battery, as you will need some ballast.
            Keep us posted, Regards Ray
            #94058
            David Walker 17
              @davidwalker17
              I have approx drawings but that just for the Mock up .Until i can go and see the last one still arround and take some measurments i wont go much further in the pre build . Its 39` long beam is !0`9" draft 3.6"They will be heavey as the frames will be oak and planking in pine
              David
              Edited By David Walker 17 on 04/03/2021 16:24:58
              #94061
                Assuming that they are intended to go like fishing boats, something like a 540LM, or a 545, run on about 3/4 the volts on the label driving a prop about the same diameter as the motor can.
                A heavy SLA battery helps with ballast, on the other hand a lighter battery such as a NiMh lets you put the ballast where it is needed and gives more opportunity to choose the voltage that you prefer.
                Building heavy is not always the best option – there was a case in one of the magazines many years ago where the builder had a fixation with ultimate strength. He was upset when he found that it floated below water line before any working bits were added, and that rather than a working model, he had a rather nice display only one.
                Edited By Malcolm Frary on 04/03/2021 17:29:28
                #94064
                  There's a guy on the Model Boats web-site who is building the very same boats. He may be able to help! wink
