Hi Mike,
Short answer: no, not really.
Longer answer: well, it depends. Most things can be done if one really wants to do them. However, covering a GRP hull with wood planking would, to my mind, rather defeat the purpose. When it come to kits, there are several reasons why a GRP hull might be chosen over a planked one. GRP allows the kit producer to furnish a ready-made basic hull to the customer, and one that can be produced over and over from the same moulds. Also, when appropriate the hull can come with a lot of surface detailing, such as rivets, plate lines, rubbing strakes, planking etc., or inversely, be made slick and smooth if it is that sort of a hull.
In any case, at least part of the interest for the builder of such a kit is that it saves a considerable amount of work and thus time. For some, this makes a GRP-hulled kit more interesting, while others finds it less so; yer pays yer money and yer takes yer choices …
So while some GRP hulls will need some detail added to the outside of the hull — chines for example, or rubbing strakes — I've not yet seen one that was intended to serve as just a base for a complete, external planking of the hull. I would even go so far as to say that I would consider it inadvisable, compared to a conventional plank-on-frame planked hull, as it would be rather more difficult to fasten the planking except with some quite strong and properly waterproof glue — epoxy comes to mind — which would take a long time, and be both pernickety and potentially messy.
Mattias
Edited By Banjoman on 16/09/2019 08:58:12
