Thanks,
U-Tube takes a bit of getting used to. The pictures initially went on in the wrong order and I had to push them into the correct sequence which is difficult when they are mixed up. I think next time, I will number them in the images and then it will be easier to re-arrange them correctly.
They have a selection of background music, but I couldn't find any pre-listen button, so I had no idea what it was like, so left it off. No doubt I will get better at it as time goes on.
It is a very neat way of putting a display selection on though, and I like the way they fade them in and out. You can select any number of seconds, and I finally settled for 4! Any longer and it seems to drag. The show can be paused by clicking on the image. Then re-started by clicking on it again.
Wonder if anyone else uses it, that could give us some more tips?
