I have decided to sell my part built Highlander Clyde Puffer as I have spent a lot of time on it and I don't think that I will ever get it finished. The work I have done so far is to a high standard. It comes with all the original fittings contained in their numbered bags apart from the ones I have already fitted to the hull. The drawing is there, as is the supplied 4 blade brass prop. I have installed an MFA Torpedo 500 motor with 6:1 reduction gearbox and an aluminium smoke stack which I thought would look better than the one supplied. I will also include some Model Boats back numbers with build descriptions. It is to 1:24 scale and measures – length 33" (838mm), beam 9.5" (235mm), disp. 15lbs (7Kgs). It will all be contained in the original box.
I would like £295 ovno (it cost me £385 last year for the kit and then whatever the MFA motor cost me. If I get my asking price I will ship by courier for free, fully insured otherwise I would charge a fairly nominal £10 (UK mainland only).
Derek Bradley.
