Hi Andy. There is no best combination to use. You will get likely several suggestions here, all of which are likely to do the job, and you make your choice.
What size props are you going to use, or at least, what is the scale prop size? As this has a bearing on the motor choice.
Do you have some batteries to use from (for instance) any other boats as this could also affect motor rating (Kv), assuming you would want to re-use batteries and not buy the Lipos which will be suggested.
Edited By ashley needham on 06/07/2020 10:48:25
