Hello,
although this question has been posed many, many times before (and I've spent many hours reading all the answers here – thanks to all who have taken the time to reply in the past), I'd be very grateful if the collective wisdom of this forum could be brought to bear on my problem.
I was recently taken by a magazine article detailing the building of a much-simplified dynamic-diving submarine. I'm in the process of designing my own version based on the principles from the magazine (essentially a squared-up hull, small, sealed equipment pod and all ply and balsa construction) and am now considering motor options.
My model will be 1m long with a beam of about 60mm, based on a type-ix u-boat. As the full-size has twin motors, I'm designing mine to have the same, despite the complications and potential over-powering this implies. At 1m scale, the largest propeller possible is 20mm diameter and, as a nod towards authenticity, I'll be using 3-blade props, probably from Raboesch.
My current plan is to use 2845 in-runner brushless motors on separate 30A ESCs. It's tight inside the hull, but there's just room for a 2S 2200mAh battery – running time will be about 4 minutes at 60% duty-cycle with these motors. I'm a bit undecided, though, on whether I should go for higher or lower-speed motors. Even though the props are tiny, to my mind I don't want to spin them like mad and just thrash the water up behind them, but maybe I'm wrong?
Something like a BM400 from Overlander would give 2100KV, so about 15500rpm unloaded at full power. The Turnigy XK range could give as low as 1980KV for about 14600rpm or a 3650KV version for about 27000rpm. I prefer brushless motors in any setup, but would brushed be a better choice here?
Any thoughts and opinions would be very gratefully received. Apologies if that was all rather long and meandering – I suppose a tl;dr would be:
What's best for 20mm props, slow or fast?
What's best for props on a submarine, slow or fast?
Thanks very much
