Hi Jerry,
Been to Moreton and grabbed some pictures for you and put them in my gallery "Kens bits" along with a sketch showing how the two servos operate the rudder. You will be able to see these when they appear !
An interesting note I discovered is not only can you reverse using this rudder but you can also control the forward speed and even bring the boat to a stop with the engine running ! – just by partially closing the rudder halves.
you will need to be quite good with a soldering iron as I’ve not found anyone yet selling them – though I’m sure someone must. You need a brass rudder post, on this slide two brass tubes, one over the other, and the two halves are fixed to these.
Two servos operate the rudder. The steering servo (nearest to the rudder) is mounted onto a small board, this in turn is fitted between two brass channels and is able to move back and forth in the channel.
The second servo is mounted behind it, and its this servo that slides the other. As the steering servo is pushed forward the two halves of the rudder will close, effecting reverse
Hope this is some help – Ken
Now before you have a go at me Vinnie, I put these pictures up at 18:05 tonight. It is now 19:00 and no sign of them so they are not instant. Well I thought they were pictures but must have sent some Avatas by mistake ! or the I.T. boys are telling you porkies.
What we need here Vinnie, is for you to join the forum as a member, create an album and send a couple of pictures to it – you must however use your own, home computer and not a works one. If yours go live instantly, let us know which computer your using and we can all buy one ! – you must not use your influence as moderator in this exercise.
