I took my Model Slipway Tamar for a sail the other day, no problems, good turn of speed, batteries lasted about 45 minutes.
Yesterday I was tidying some wiring in the hull when I noticed that the main fuse in the Action P92 Power Distribution Board had melted, well the green , plastic had! Surprisingly fuse and the board were still working. The green plastic was now a solid globule on the circuit board. It took a bit of careful prising and poking to remove the plastic and remains of the fuse but on replacing the fuse, the board was still working . Then I realised that the green fuse was a 30 amp, I don't remember when I put that in, it should be 25 amp.
Putting the board back in the boat and connecting up, all seems,to be working.
Has anyone an idea how the fuse could be so hot but not blow.
The boat is using 9.6 v batteries, Graupner 600 ECO motors and 35mm plastic 3 bladed props, with a separate 6v pack for lights, radar, and bow thruster (Speed 400) .
I am wondering if the 9.6 v batts are too much for the ECO 600 , so should I change to 8.4v packs or perhaps to 12 v motors.
