Mini-lathes for mast turning
Home Forums Building Kits Mini-lathes for mast turning
  • #47618
    Alex Morgan 1
      @alexmorgan1
      Is anyone able to recommend a reasonably priced (£100 – 200) and reliable supplier of mini lathe for mast turning please?
      Alex
      Alex Morgan 1
        @alexmorgan1
        #47619
        Keith Long
          @keithlong89920
          Alex
          At that price range all you'll find are second-hand or toys!
          "Mini lathe" covers a multitude of machine definitions according to who describes it, you really need to think through just what size machine you need and what materials you want to work in. If you are turning masts and spars from wood then think more in terms of machines for wood rather than the far east "mini-lathes" which are really aimed at metal working. If you DO want to machine metal then that will be another thing to factor in. Without being rude to anyone – or hurting feelings – the accuracy demands for machining masts and spars are totally different to those required for making pistons and cylinders for steam engines and could be met within your budget by careful consideration of just what you want to do. Don't dismiss old machines, while they may no longer be able to keep the accuracy and precision for "engineering" they will still be capable of giving good service for less demanding tasks. The main issue will be that generally they don't operate at high enough speeds for wood turning though, and the bearings won't take kindly to being pushed that fast, but if you can live with the speeds that they will run at, you'll most likely get a far more robust and rigid machine – and rigidity is important for good work.
          A lot of the older machines from the early 20th century were made for turning both wood and metal and accessories for both types of work were available. If you go that route you'll probably become VERY familiar with EBay. Don't dismiss that route too quickly all my machine tools have come through that route and I'm happy with them, but I do have a background in engineering so I'm willing to trust my own judgement to decide if a VERY second hand, used (and probably ab-used) , worn machine is worth buying for ME – I'm NOT making aerospace components!
          Good luck in your search, a lathe really is a VERY versatile machine, with ingenuity it's amazing just what you CAN machine on them, milling becomes a possibility as well.
          Keith
          #47620
            Hello Alex
            I would try making your own simple wood turning lathe!
            Used a variable speed electric drill, for the headstock, clamped accurately to a robust wooden base and improvise the rest!
            Keith Long
              @keithlong89920
              Alex
              Just to second what Bob has said, many, many folk have made their own wood turning lathe, they can be as simple or as complicated as you want to make them, from the pole lathe used by the "bodgers" making chair legs and spindles, on site in the forest to incorporating CNC ideas ( probably not for a home project just yet though).
              Axminster list a drill powered lathe in their catalogue for about £35-£40 if you don't fancy building one for yourself, you'll need to check the price 'cos the catalogue I'm looking at has vat at 17.5% NOT 20% and is at least 5 years out of date . There are also many designs for simple wood lathes on the internet, some using timber for the bed and some using angle iron or pipe. A wood turning lathe is pretty simple to construct using basic tools.
              Don't forget to allow for the cost of the gouges and other turning tools that you'll need, they all add up.
              If wood turning is really what you want to do then your budget is fine to start with, but the "mini-lathe" really isn't the place to start. If you were thinking of more general turning including metals then that's a whole different ball game.
              Keith
              #47623
              mike farrell
                @mikefarrell21522
                Alex Added thought , make sure you get a good speed lathe such as a Rexon V6 because you will need the speed it will give you to turn fairly thin dia. Rexon is a variable speed (800 to 3000 rpm) As advised try ebay for a second hand or try Rexon in Rotherham ,they have refurbished tool from time to time. Mine is not for sale .Good luck Michaelwink
