Masking pin striping
Home Forums All things floating Masking pin striping
  • #35154
    Greg McKenzie 1
      @gregmckenzie1
      Years ago in my hot rodding days you used to be able to buy masking tape that after it was applied, a central section could be removed leaving a gap that paint could be applied making a line.
      I have done a search but have not come up with any suppliers. It was a much easier scheme than two bits of masking tape.
      Greg McKenzie 1
        @gregmckenzie1
        #35155
        Kimosubby Shipyards
          @kimosubbyshipyards
          Greg,
          I've some of this, at 1mm wide in an initial strip about 5mm width. I got it from:-
          http://www.miskinmodels.co.uk
          It's great for water lines at small scale, and for hull markings and deck stripes etc.
          Kimosubby.
          #35158
          Greg McKenzie 1
            @gregmckenzie1
            http://www.tcpglobal.com/pinstriperdepot/psdfinesse.aspx
            I was given this web site by a car restorer in the states and it looks promising
            #35160
              or try http://www.hobby.uk.com. comes in a roll containing various widths
              Greg McKenzie 1
                @gregmckenzie1
                Where did hobby hide it?
                #35164
                  Trimline it is called, you get 2.5m of sticky stripes, various widths all same colour per roll £2.95
                  Greg McKenzie 1
                    @gregmckenzie1
                    Have ordered some Trimline from Hobby and am looking forward to its arrival. Thanks for the "Heads Up"
                    #35229
                      Trimline is good stuff. Some people are put off because it is a tape rather than paint but in fact it is so thin that it looks just like a paint line, particularly if the hull has been subsequently varnished (although this is not strictly necessary).
                      OK, you can detect it if you run your fingernail over it but do you really want people doing that to your precious model?!
                      Greg McKenzie 1
                        @gregmckenzie1
                        Hobby did a great job as it arrived today. Now to apply it !!!!
                        #35408
                          Be careful not to stretch it when applying. Just let it lie naturally and press down with a cloth or something similar.
