mahogany sheet
mahogany sheet
Home Forums Beginners mahogany sheet
  • #2851
    Paul Beeney
      @paulbeeney58354
      Paul Beeney
        @paulbeeney58354
        Hi all
        Can any one tell me were I can buy Mahogany sheet that is real thin ie 0.5 mm or thinner in the Surrey area please
        Thanks paul
        #83197
          Unless you are incredily lucky by having a well stocked craft shop in your area, I expect that you will be looking at mail order. Look for "mahogany veneer". Most of the Amazon listings appear to be pre-glued for ironing onto surfaces.
          A combination of balsa, mahogany stain (for colour) and wet rot wood treatment (to increase surface strength) from a large DIY store might be the best answer. Finding somebody who stocks balsa (or obechi) sheet locally would be an achievement these days.
          #83198
          Banjoman
            @banjoman
            Paul,
            Mahogany sheet 0.5 mm thick is available by mail order from i.a. Cornwall Model Boats (**LINK**) and The Model Dockyard (**LINK**). Both are reputable vendors that have been around for years, and from whom I would not hesitate a second to make an order.
            Mattias
            Edited By Banjoman on 31/07/2019 10:44:46
            Edited By Banjoman on 31/07/2019 10:45:06
            #83199
              Hi Paul,
              Try Mantua Models at Windsor, I have used their 1.00mm extensively , and not a million miles from Surrey, but they do have a website. T you use waterbased varnish it looks like Teak, with oil based varnish just like Mahogany wm31.jpg
              Roger Clark
                @rogerclark
                SLEC.ltd & Hobbies both do 0.8mm mahogany sheet
                #83224
                Andy F
                  @andyf73386
                  Ebay. A good source for most things including mahogany veneer. Admittedly 0.6mm but…
                  Ebay link
