Catches… the front hatch in the last picture is sat on a small flat ledge, to keep iheld down I fabricated some plasic slide bolts on the underside that are accessed through the centre hatch door. So lift of tight fitting hatch door poke finger in and retract slide bolts to lift od access panel.
Early this morning I cut out the bow logo and stuck it on
This needed doing because as Duckie said it start to need paint ! So when i got home from work it was out on the garden table AKA spray booth for its first coat of primer
After tea and a bit of olympics the sunshine had worked is magic and allowed the hull to be flipped and a second light coat, this time on the upper side including inside.
Realising this is going to put the hull out of action for the coming days as it hardens, gets rubbed and subsequent layers added, i purposely didnt prime the wheelhouse so I can carry on with that.
Dont panick its not got its roof glued on !!! Although the instructions say to glue the roof on when inside is comple.. I dont like glued lids so i made a couple of mods to allow the back edge of the roof to slide under a lip on the funnel base, created from plastic offcuts. Combined with a tiny screw through both front corners of the roof, just behind the sun canopy and the roof is now removable.
