Due to significant personal changes I have decided to change how scratchbuildwithJohn works. I am now in the early throws of battling cancer. Not fun.
Previously, access to all the videos was only possible through membership and many of the videos on U-Tube were restricted.
From now on, all restrictions will be off. All my videos will now be accessible on U-tube, however the website is still the best place to go as the diagrams, codes, and plans will be there. Plus it is easier and more intuitive to navigate.
So, that’s the downer stuff. Let’s get to the LA.
This Sunday I will take the boat to the local club house and drop it into the water for the first time. This will not be to sail it per se, just to ballast it. If all goes will we will have a sail around on the surface.
This week I have been fixing apparent bugs. All these little issues will be addressed in the ‘want worked and what didn’t’ at the beginning of the video series but I am still in testing mode right now. More bugs will spring up.
The first is the laser sensors. If you remember I had some inaccuracies in their use, in that after I turned them on there appeared to be variation for 5 minutes. Not good. Also I noticed differences when the lasers were in the dark or light. Of course they will be in total darkness in the sub, apart from LED’s blinking etc. So I addressed the adafruit team and they sent the following diagram and suggested I reduce the distance between the sensor and the piston. So I have done that significantly and it works far better. My initial testing that led me to setting them back was clearly flawed.
Secondly I re build and designed the output of the main motor utilising the fantastic capacity of the brushless motor to be replaced with an extended version, completely removing the necessity for a second connector, which was producing vibration.
Then I started adding ‘in wall foam’ to the sub hull, limiting it with, yes, glad wrap, and aluminium flashing. Once it had dried it looked hideous but a few slices with my knife fixed it. I added more where necessary and then ensured that there were drainage holes. Then I sealed the ‘holes’ with good old fashioned ‘no-more gaps.’ (I know no-more gaps will not seal, but it will fill holes). Once that was dry I used plasti dip to pain the foam plugs. That does seal.
I may add that I had a comment from a subscriber that if the foam is not properly ‘set’ it can expand again if exposed to heat such as sunlight, thus blowing up the boat. It was quite a scary story so I levt the hull in the sunlight for a day to make sure it was set. It was and did not expand any further. I will do that from now on!
Then I started to do a better job of sealing the servo that sits in the water. (Under the conning tower). I think the method is about as good as it gets. I used dual mix silicone to fill the electronic part of the lower half of the servo. I then drill a very small hole into the top, and using a syringe to add baby oil. Filled it to the top. I am using see through servo’s so I can ensure they are full. I sealed the tiny hole and it works.
So on Sunday I will set the pistons to where I think neutral buoyancy should be, and drop it into the water. I am hoping it will float nicely. Then I will add led to get it to the magic state, and take the boat out and add the led. Retest it and take it out.
Then I will set the pistons to full buoyancy. I will take the WTC apart to do this as I don’t want pressure issues. Then I will drip it in again and adjust the pistons to get the boat to it’s best position.
Out it will come, and I will take it apart and connect the arduino to lock in the positioning of the full flotation settings.
Then comes the big test. I will open the boat up, drop it in the water and withdraw the pistons. Pressure will build up and I will test for leaks.
If there are no leaks, I will take it for a run.
For the whole blog with pics..
Big day
