looking at building the Glynn Guest Empress, but it requires a minimum prop shaft length of 14 inches. Havent found anywhere on line to purchase one at this length, can anyone help me out with a link ?
SHG Marine sell 14 inch shafts. The 14 inch refers to the tube length so you might need a 15 inch tube. The shaft extends about half an inch at each end.
Ashley is right, there is a risk of the shaft whipping at 4mm but SHG, and no doubt some of the other suppliers will sell you a tube with a 5mm shaft which would probably be safer. You will then obviously need a prop with an 8mm thread.
