Logging in
Logging in
Home Forums Soapbox Logging in
Viewing 13 posts - 26 through 38 (of 38 total)
  • #19054
      Thank you 100 Watt…………………You`ve just been promoted!
      There was about 150 Cookies in the virus vault, which I`ve deleted, but non of them were Modelboats related.
      Bob with a 2 amp fuse
      60watt
        @60watt
        In this case, the effect of following my suggestion makes no difference unless your problem was confined to a browser not storing  passwords & login.
        Nevermind,it will do if you ever roll two dice and get a 6,7 or 8 to solve internet problems .
        1 is yes.Two is no.
        oops!
        13 for a No!
        #19164
          Hello Colin
          Just a quick question.
          What is the “time out” period before we have to log in again, I have noticed that if I am on the pm section and replying to a message if I am not quick then I have to log in again and the message is lost.
            Hello Paul,
            No idea! I will see if i can find out. I’ve never had the problem myself.
              Thanks Colin
              Its not urgent its just a puzzle that throws me from time to time.
                Can`t post pictures into the forum………….when I select……..”insert image”…….the system hangs up with the hour glass symbol
                Edited By Bob Abell on 27/04/2009 16:28:23
                #20485
                  Sounds like a repetition of your previous problem Bob. Have you tried shutting down your PC and rebooting?
                  Edited By Colin Bishop on 27/04/2009 17:02:46
                  #20486
                    I have had the same problem when uploading the barrel back photos, I suspect that the site cant cope with more than 2 large jpg images during any single transfer so I stick to uploading one image at a time.
                    Works for me.
                      Paul,
                      The Tech Guy advises me that it’s not a good idea to upload large image files as these can run into problems – not just confined to this site. They get cut right down once they are on the site anyway so there is no real point in doing this. It’s best to make a “desktop resolution” copy and upload that which only takes seconds. Image resizing programs are widely available and I have recommended two in the FAQ section on the left hand side of the home page. I have been uploading dozens of photos for the Article Database using this technique and the only time my upload failed was when I included some full size images in error!
                      If an upload fails, it seems that the connectiion is not always broken which “locks” things up when you do anything associated with the photos. I’ve found the only way to reset this is to close down the browser entirelyand reload or reboot the PC.
                        Thanks Colin…………..I`ll try that again………….(My pictures are 600 pixels across)
                        Paul……………Have you posted a picture today?…………….Haven`t seen one?
                          Still doesn`t work at this end!
                          In fact, I don`t think anyone has posted a picture today…………..(after a quick look)
                          Edited By Bob Abell on 27/04/2009 17:44:15
                          #20491
                            Had no trouble with this one of my Cumbrae Bob….
                              Oh dear……………….zzzzzzzzz
                            Home Forums Soapbox Topics
