italieri s100 brushless
Home Forums R/C & Accessories italieri s100 brushless
  • #79146
    Empire Parkstone
      @empireparkstone
      Want to put a pair of brushless motors to replace existing 380 /385's (tried both)
      Props are 3 blade 30mm . what motors would be suitable and esc's with reverse
      Thanks
      Empire Parkstone
        @empireparkstone
        #79147
          Still building mine at the present. But I have 2 x 380 on the outer shafts which will drive 30mm 3 blade plastic props. Centre motor will be a Leopard 2826/17 brushless driving a 35mm(?) 3 blade prop.
          If that doesn't work I may change the outer motors to brushless at a later date.
          Esc for the brushless will be the 30 amp marine from Component Shop.
          Edited By Tim Cooper on 30/09/2018 10:24:53
          #79149
          Empire Parkstone
            @empireparkstone
            Thanks Tim wont the 380's limit you to 7.2v unless you use individual batts which is gonna be a bit crowded
            M P
            #79153
              MP
              I have a small 8.4 v battery for the brushless motor. Depending on the final wt I might squeeze a 9.6v in.
              How did you arrange access to the inside? Looks difficult to provide access to both sides of the outer motors, especially if I want to change the motors later.
              #79157
              Empire Parkstone
                @empireparkstone
                The Whole Deck is removable tell me you haven't glued it down
                M P
                #79159
                  No . I haven't glued it down. But I didn't think it would watertight just to rely on the screws.
                  #79160
                  Empire Parkstone
                    @empireparkstone
                    It is not too bad on water ingress unless a bit choppy but I found it did not like choppy anyway
                    M P
