Hi Pat,
Thanks for posting the images, all is clear now! The hull of the ship is essentially intended to be solid, made up of 'slices' of wood stuck together with glue (bread & butter construction) and then carved to shape on the outside by removing the 'steps' between the slices as shown by the shaded shape on one of the pieces.
The 3/4 inch and 1/2 inch notes indicate the thickness of the respective slices.
Unfortunately this is incredibly wasteful in terms of the amount of wood used and probably reflects the fact that back in 1960 it was still possible to get hold of suitable pieces of yellow pine cheaply.
You could make the model out of balsa but the thicknesses will be quite expensive and your best bet would be to make up the 3/4 inch slices with two slices of 3/8 inch balsa and perhaps the 1/2 inch slice with two 1/4 inch slices.
You can purchase the wood from SLEC **LINK** or Cornwall Model Boats **LINK** and other suppliers.
The sheet normally comes in widths of 3 inches or 4 inches so if your model is less than 6 inches wide use the 3 inch width, if less than 8 inches wide use the 4 inch width.
I seem to recall that the model length is 13 inches so you will get two slices out of one length of sheet.
It is best to get medium hard grade balsa for this sort of project – see the SLEC site. Ordinary white woodwork glue will be fine for sticking it together.
While you are checking out the wood suppliers, keep an eye open for the wood you will need for the other bits of the ship. For example, a quick look would suggest that the sides above deck level should be of 1/16 inch plywood. If building from balsa then you will need to seal the hull for painting. This could be done with dope (smelly) or a water based resin such as Eze Cote which is more pleasant to use but that is a little way down the line yet.
Hope this helps,
Edited By Colin Bishop, Website Editor on 30/12/2013 17:20:41
